Home › Forum › Ask A Member › MK 28 ID Tag
  • #197099
    Matthew Pieklik
      Getting my Mark 28 ready for paint. What is the best way to remove the ID tag without destroying it. I’m Not seeing any holes behind the pins. Maybe I need my other glasses. Thanks All!
      #197123
        there are no holes behind sorry.
        #197431
        oldcollector
          I think I see in one of your photos that the plate looks bent. When I have this problem I remove the plate to straighten it and to paint under it. I have taken a 1/2″ or 1″ Comercial Hack saw blade about 8″ long and 1/16 in. thick and ground down one end of it to a sharp point with a grinder.(these are very hard blades). Put the sharp end of the tool about mid way on the pin head and tap on a slight upward angle, this will loosen the pin,if not tap on the other side of the pin.when the pin is raised up just a little bit it will pop out very easy. If your plate is straight just mask it off with Frog Tape,trim with an Xacto knife and paint.
