Home › Forum › Ask A Member › Motor ID and service info tags
- This topic has 4 replies, 4 voices, and was last updated 2 years, 2 months ago by
JACQUES.
June 13, 2024 at 8:40 am #288281
So my collection keeps growing (60+) and it’s getting harder to remember what year an outboard is, gear oil, gas oil mix ratios etc and of course the last time I serviced or ran the motor. Does anyone have a source for a nice looking, durable engine ID and service tag before I go and design and print my own?
June 13, 2024 at 10:21 am #288282dollarstore Amazon …..plastic key tags not fancy but does the job
June 13, 2024 at 1:21 pm #288284I tag all my motors with a number. Then I made a document form with all the required information and I fill in the blanks. Number being on top.. Half of the sheet is left with lines so I can write what I did. I have about 40 so far. I Log them as I go . I have some on the rack I haven’t got to yet. It seems to work pretty good.
We should make a book of all of Buccaneer’s Projects he has posted. That is a whole wealth on knowledge on its own.
June 13, 2024 at 6:46 pm #288285I tag all my motors with a number. Then I made a document form with all the required information and I fill in the blanks. Number being on top.. Half of the sheet is left with lines so I can write what I did. I have about 40 so far. I Log them as I go . I have some on the rack I haven’t got to yet. It seems to work pretty good.
10-4 on the Buccaneer dude! He knows his beans! I have my motors tagged with one of those brown manila tags. You can buy them on ebay for cheep. I like to jot down on the card stuff like: last ran, problems especially leaky gear cases, they need to be drained before freeze up or things that need attention, model and serial numbers also special names that might apply to an individual motor. (Carl or Hojo or Lumpy) I also have a running inventory folder in the house. I buy old sweat shirts at the good will store. I use them for a storage cover. Usually we cut the sleeves off and sew the neck and the sleeve openings together. My babies are all inside covered up and they still get covered with dust and dirt and fly droppings and spider nests, mud dubbers and who know what all else.
dale
June 13, 2024 at 7:56 pm #288286Windows EXCEL accounting software is an excellent information tracker .
you can list them on the left most column by topic of your choice (HP, MANUF.etc… ) and create other b-c-d-e-f-g columns next to it with each column name by your choice ex HP -SERIAL|- SHORT/LONG SHAFT- COLOR-LAST OIL CHANGE- DTE LAST USED- etc.. etc.. as much info as you want .
You will never run short of space to list new comers and you can print landscape to preserve the info incase your PC goes South . IF you enter them by HP in column A you can re-sort them all by HP when done . In fact you can re-sort endlessly by colum
here is a basic sample …yours to create and customize
