Home › Forum › Ask A Member › Motor ID Needed
- This topic has 6 replies, 5 voices, and was last updated 1 year, 10 months ago by
Bob Wight.
December 17, 2024 at 7:09 pm #292696
I saw this motor for sale on my local Craigslist but I’m not sure what it is and the seller has no idea either. Anyone have an ID?
"Every time you remove a broken or seized bolt an angel gets his wings."December 17, 2024 at 9:26 pm #292698It looks similar to my 1950 Fastwin, but has differences.
December 17, 2024 at 10:02 pm #292703Johnson Model SD, the profile of the powerhead and the water outlets in the prop are a dead giveaway.
Best,
December 17, 2024 at 11:39 pm #292708Thanks for the ID. If I find it’s not seized up I may go ahead and pick it up.
"Every time you remove a broken or seized bolt an angel gets his wings."December 18, 2024 at 7:58 am #292711from the book
December 18, 2024 at 9:09 am #292713Yup its an SD of some vintage. Some of those old girls had a pressure tank mounted on the motor. Direct drive and vacuum cooling. I can just make out the holes in the prop. They were made in the late 40’s. I have an SD20 1950 16hp. I had a heck of a time finding a twist grip, Fisherman6 fixed me up with one. It should make you a good project. Looks like it is all there.
dale
December 18, 2024 at 11:32 am #292720I haven’t taken on a new project in quite awhile now, so the bug has started itching me again. Waiting to get a little more info from the seller.
"Every time you remove a broken or seized bolt an angel gets his wings." -
