Home Forum Ask A Member MQ-11C Fuel tank
  • #285022
    James Hamilton
      I got an MQ-11C J2559632 9.5 HP without a fuel tank.
      I’ve looked a few times on these board and online and an not sure which system would work.
      Initially I just want to run it, then worry about historical accuracy.
      What should I get just to get on the water?
      Jim
      1962 JW-17 Johnson Seahorse 3HP (I have 3 of these-2 running)
      1965 Evinrude 3533A R 67.15 Evinrude Yachtwin 3HP
      1958 Johnson 5.5 HP
      1965 Johnson MQ-11C J2559632 9.5 HP outboard
      2022 Honda 2 HP
      2005 Yamaha 250HP
      #285023
      crosbyman
        Canada Member - 2 Years
        any single line tank  with  an OMC   J/E type fuel connector will work… suggest you get an old one with just a vent on the fuel cap.    mix 50/1
        if yours  does not have the  vibration  dampners  kit   they  can shake quite a bit   and will sometimes self  choke  themselves by poping out the choke button.
        fussy  carbs…. keep it clean
        #285932
        James Hamilton
          Thanks, I will keep them clean!
          I got a great tank from the GasTankMan!
          beautiful.
          1958 Johnson 5.5 HP
          2022 Honda 2 HP
          2005 Yamaha 250HP
