Home › Forum › Ask A Member › mystery engine
- This topic has 11 replies, 7 voices, and was last updated 6 months, 2 weeks ago by
seakaye12.
August 20, 2024 at 9:47 am #289979
Trying to identify this engine. It is 2 cycle with a WICO flywheel magneto and a tillitson carburetor. It has been suggested that it might be a West Bend or an Elgin/Westbend. Both the tags are missing. Thanks. Derek
August 20, 2024 at 2:03 pm #289989It looks somewhat like a Sears Elgin. I see similarities in the pointed tank support and the “arrowhead” shaped advance lever.
August 20, 2024 at 4:25 pm #289990The carb knob is Elgin for sure
August 22, 2024 at 2:44 pm #290083From the way the gas tank and the engine is mounted I would think this would be for an inboard application. What do you think? Anyone have any paper work on this engine. I’ve looked at several Elgin sites, but have been unable to find any pictures of this engine. Thanks for all your help.
August 22, 2024 at 5:45 pm #290097From the way the gas tank and the engine is mounted I would think this would be for an inboard application. What do you think? Anyone have any paper work on this engine. I’ve looked at several Elgin sites, but have been unable to find any pictures of this engine. Thanks for all your help.
I wouldn’t think it would have been a factory made “inboard”,
if they didn’t start making Elgin’s until 1946.
Was anyone wanting inboard motors that late in the game?
Perhaps a small powerplant to run a pump, etc?Prepare to be boarded!
August 22, 2024 at 11:05 pm #290107A couple of observations… The cover on the front of the carburetor and control knob looks strongly like Elgin, even the OD green color.
Also, note the bosses near the pully sheeve, looks like something was to be mounted, could have been a belt guard, or perhaps a screen guard for a fan.
Very interesting set-up for sure
August 22, 2024 at 11:20 pm #290108My guess is someone adapted an Elgin power to that belt drive. Gas tank and its mounts look to be home made. Wonder if it performed as intended? Very interesting. Would like to know more. Tubs
August 23, 2024 at 12:39 am #290109I would like to see the connection of the carb to the Crankcase… see if someone made an adaptor plate to rotate the carb from vertical orientation to horizontal .
August 23, 2024 at 5:03 am #290110My guess is someone adapted an Elgin power to that belt drive. Gas tank and its mounts look to be home made. Wonder if it performed as intended? Very interesting. Would like to know more. Tubs
It sure does look like it was “field engineered”. I wonder if it has reduction gears.
August 23, 2024 at 5:51 am #290111That mounting base and blower housing with an integral support sure does look good for homemade–if that is what it is.
