Home › Forum › Ask A Member › Need Help Removing Elgin Impeller
  • #50968
    rpsiii
      stxray,
      If you had to cut the shaft, as I suggested, and you need a lower shaft, I have one you can have.
      It is still in the gearcase and the gearcase is cracked but the shaft is fine. (I found this one
      AFTER I got one from Doug Penn and did my repair!)
      If you want it, it’s yours for the price of the shipping.
      PM me if you are interested.
      Respectfully,
      Bob S
      #50970
      stxray
        quote RPSIII:
        stxray,
        Respectfully,
        Bob S
        PM Sent
        #51570
        stxray
          Update: We are up & running.
          After much frustration, I had to cut the shaft. With the shaft cut, I was able to retrieve the coupling unit from inside the motor leg. I figured once I had the coupling unit in hand, it would be easy to knock out the remaining piece of the shaft — not so. I tried numerous chemicals and heat but it wouldn’t budge. I tied using a pin punch tapping on either side of the center pin but, no go. What finally worked was to remove the center pin from the coupling unit, placed it over an open vise, and using a 3/8" socket extension took out my frustration. Finally, little by little it started to move.
          Once out, I was able to install the impeller and the new shaft (thanks to RPSIII) and we are back in business.
          Thanks to all who responded and especially Bob S(aka RPSIII). I couldn’t have done it without you guys.
          #53639
          brian
            I’m always trying to make a tool to do stuff. I’m wondering if a person could fabricate a tool to force it apart. I had several of these outboards but never got around to wrenching on them.
