Home › Forum › Ask A Member › Need OMC Crankshaft Journal Specs
- This topic has 6 replies, 2 voices, and was last updated 5 years, 4 months ago by
Bob Wight.
August 1, 2020 at 9:37 pm #210602
The motor is a 1959 Evinrude Fastwin
Crankshaft P/N is 0304733 : Replaced by 0315286
In particular I need the size specs for the center main bearing journal.
Thanks !
August 1, 2020 at 9:50 pm #210603Don’t have the Evinrude specs handy but the comparable Johnson FD series with that crankshaft shows 0.9995-1.0000 for the center bearing journal.
"Every time you remove a broken or seized bolt an angel gets his wings."August 1, 2020 at 9:53 pm #210604Yikes that was fast Bob! Thanks!
Yes; the Johnson should use the same crankshaft.
I’m curious…..what Johnson Manual are you using to find that information? I have the 10th Edition and so far specs like that are eluding me…..
August 1, 2020 at 10:32 pm #210605Somewhere along the line, I came across some Johnson Condensed Service Data. Here’s a copy – a little hard to read since I had to reduce the file size.
"Every time you remove a broken or seized bolt an angel gets his wings."August 1, 2020 at 10:49 pm #210609Sorry, sent wrong file. Try this onel
"Every time you remove a broken or seized bolt an angel gets his wings."August 1, 2020 at 10:49 pm #210611Bob I just sent you a PM
ChuckAugust 1, 2020 at 10:54 pm #210612Chuck,
Just responded to PM.Bob
"Every time you remove a broken or seized bolt an angel gets his wings." -
