Home › Forum › Ask A Member › need some wisdom on 9.5hp shift handle gear line up to lateral cam
- This topic has 7 replies, 4 voices, and was last updated 5 years, 4 months ago by crosbyman.
December 2, 2018 at 1:42 pm #157889
did the electricals on the mag plate and reinstalled it .. hooked all the little cams etc.…
now my shift handle is slipping gears as if not enough of the gears match up to the lateral cam that turns the mag plate linkages
any suggestions to match the up.. .so I can turn the shift handle to reach the full range of the mag plate
thanks
December 2, 2018 at 2:09 pm #157891I don’t really understand the problem you are having…Is the engine jumping out of gear? Maybe you can post some pictures
December 2, 2018 at 2:42 pm #157896Are you speaking of the rack and pinion gizmo on the throttle? First tooth on the pinion engages the first notch on the rack.
December 2, 2018 at 8:51 pm #157966Frank when I turn the throttle handle the gears in the back seems to engage just a f ew notches then spins freely
preventing the mag plate from doing it’s thing from stop to fastI’ll verify ” first tooth first notch tomorrow see If I can line them up
it was working before so I must have jumped a couple of notches……how ??? Don’t know
it won’t win….
December 3, 2018 at 2:59 pm #158478found the problem … 🙁 the lateral push rod that converts the rotation of the tiller handle into left to right movement to rotate the mag plate has worn gears
when the tiller gears mesh into the push rod they meet up with a worn spot then skip out
when the tiller is held vertically the gears match in unused mesh point and works perfect . Upon lowering the tiller the gears slip making the tiller speed control useless.
Voilà… I need the gismo
I think this new to me $60 turtle with 90 psi cylinders 🙂 was rarely greased anywhere in its life… but is is slowing coming out of a long coma. …..
December 3, 2018 at 3:47 pm #158479Must have something good, considering the hours that it must have accumulated. I don’t think I’ve ever seen those gears worn that badly. ‘Course it’s been a real long time since I’ve serviced any of them. Maybe that’s the last time they got greased.
December 6, 2018 at 6:58 am #158821I’ve got a lot of parts for those 9.5s if you need anything.
ScottDecember 6, 2018 at 8:20 am #158823ok thanks.
i have been purchasing a few parts . this new to me $60 cdn 9122r with 90 psi x2 seemed a good buy but has needed a few extra parts which i have acquired but due to this sickness 🙂
I have another one in the shed waiting to be serviced.
…. most turtles I have worked are around 70psi as per Leroy’s comment on turtles being somewhat low but this latest one reads 90×2 hopefully it will be running great next summer .
