Home Forum Ask A Member Need suggestions on SMALL 12 volt starter solenoid for 1955 RDE-17 25 Hp Johnson
  • #10735
    outboardnut
      I am going to keep the 6 volt starter and the 6 volt choke solenoid (putting a resistor on)
      But I need to find the smallest marine starter solenoid that would work. I plan to mount the starter solenoid inside the hood.
      Any ideas?
      #80552
      dave-bernard
        mercury has small ones.
        #80555
        outbdnut2
          A direct 12 volt replacement is Sierra 18-5807, but it will be the same size as the 6 volt one you are replacing. It was used in 35 and 40 HP Johnsons beginning in 1957 when they changed to 12 volts.
          https://www.iboats.com/shop/sierra-18-5807-solenoid.html
          #80558
          jim-moffatt
            I have sucessfully used the mercury replacement fro mnapa. its cheap and small, works fine.
            #80559
            jim-moffatt
              I have sucessfully used the mercury replacement fro napa. its cheap and small, works fine.
              #80560
                Are you mounting it under the hood? I used a small 12 V mower style one on my ’56 RDE.
                #80571
                outboardnut
                  yes – under the hood
                  #80574
                    Look for an Arco Marine solenoid #SW058 for Mercury starters. Small size and easy to mount. See Arco catalog at:
                    http://arcomarine.com/xhtml/Marine_Part_Catalog.html
                    http://arcomarine.com/xhtml/Pages%2051- … enoids.pdf
                    Part available at Marine Engine and a number of other on-line supply houses.
                    #80595
                    jerry-ahrens
                      I wonder if those solonoeids will work with a 6 volt battery? Never tried that.
                      #80600
                      nj-boatbuilder57
                        quote outboardnut:
                        …and the 6 volt choke solenoid (putting a resistor on)
                        Maybe I’m reading this wrong, but are you going to apply 12V to the 6V choke with a resistor in series to drop the voltage? (That’s what I’m reading here…)
                        I don’t know about your choke, by my choke (’57 Javelin 35HP) draws 7A. Dropping 6V over a resistor with 7A flowing through it will dissipate 42W. (P=I*E). While I realize that the choke isn’t on for very long, that’s still a mighty big resistor (and heat) to put under the cowl.
                        Check your choke’s current first & do the math. If your choke’s current is at all like mine, you may want to re-think this strategy.
                        Or am I mis-interpreting your intentions?
