Home › Forum › Ask A Member › Need TD-20 piston rings 1 15/16"x 3/32"
Does anyone have 1 15/16″x 3/32″ rings for a td-20? I am in need of atleast 3 rings. If any you can help please email me at carlbarc@aol.com
Thanks.
In case you don’t know, 41-333 ring is superseded by 378432 ring set. Might help in your search.
If all else fails you might try Otto Gas Engine Works. Says they have 50,000 rings in stock so they may have what you need even though it’s not listed. They also say they can custom make rings but not sure what that would run. Kirk
http://www.ringspacers.com/
Carl got in touch with me and I have the 378432 rings he needs.
5.5 and 6 horse rings thru ’79 will wok in the TD/TN motors.
