Home Forum Ask A Member Neptune 15B2 prop shaft thread?
  • #1707
    Doug Wilson
      US Member - 2 Years
      I just finished putting my 1945 Neptune 15B2 (2hp) back together starts right up. When bought it did not have a prop or nut bought a set prop fits great but nut does not thread on. Threads look fine. Anyone have an idea what thread it should be?
      Doug
      Doug
      turned off?
      #17781
      RICHARD A. WHITE
        The 1936 4 hp here in my shop is 1/2-13. Does that help?
        classicomctools@gmail.com
        #17790
        Doug Wilson
          US Member - 2 Years
          thanks Richard that is what I thought it looked like may get a die and see if I can get the threads cleaned up. Did not have a nut or prop with it when it was given to me bought those and coil from Doug Penn cleaned out the tank and carb cleaned and adjusted points fires right up every time. may have to get a canoe to run it on
          Doug
          Doug
          turned off?
          #17831
          Doug Wilson
            US Member - 2 Years
            checked things out tonight 1/2×13 standard coarse thread. Put new shear pin on with prop nut and new cotter pin ready for the test tank tomorrow. Starts easily so will see how it pumps water and let it run for a while.
            Doug
            turned off?
