same magneto and style of rope plate as used on the 1940 Detroiter four-cycle twin, only difference I see up top is the Detroiter used a square flywheel nut, this pump engine uses one with two flats on it a la the Evinrude Speeditwin…..
PM T2
Looks like the cylinder head is in the right place if the engine was vertical. They must have had to relocate the water outlets on the cylinders to avoid an air pocket in the water jacket.
