Home › Forum › Ask A Member › Neptune Outboard afraid of water
- This topic has 21 replies, 10 voices, and was last updated 11 years, 5 months ago by
Buccaneer.
April 6, 2015 at 12:37 am #13397
what is your oil mix maybe it needs more oil to seal things up. just thinking.
April 6, 2015 at 1:58 am #13404I believe the mix on this one was 2/3 pints to a gallon. I made a list in the garage of
most of my outboards regarding what oil mix they each take…… amazing that
so many of them were different! If all else fails, I’ll mix it extra rich. Thanks
for the idea!Prepare to be boarded!
April 6, 2015 at 4:47 pm #13413Thanks for the tips on worn out main bushings on the Neptune.
You made a believer out of me. I got it running on the stand
this morning for a few seconds. Killed it, removed the exhaust
tube. Put it in the test barrel, and it wanted to run, but not quite.
Put it on the stand, removed the prop, and test started it,
and ran for a few seconds. Put the hyrophobic Neptune back
in the test barrel and it actually started, but ran erratic, and
for the most part, would only run with the throttle closed, and
that was at a very fast idle…… but of course there was no
prop on. It only ran for five minutes until it crapped in the
barrel and died. Guess I’ll have to decide it I want to make
it a runner or ornament. Wished I had measured crank bushings
while it was apart 🙁
How much would the 60 psi compression be contributing to
the starting / running issue? I have no idea what’s normal for
this engine.Prepare to be boarded!
April 7, 2015 at 2:06 am #1345360 psi is probably not to bad for that small motor. As for the bearings, poor crankcase compression will contribute to hard starting and poor idling. If you can detect side to side motion when rocking the flywheel then your bearing are sloppy.
April 7, 2015 at 3:22 am #13459Joe, thanks for the reply. If there’s any sideplay in the flywheel it’s
minimal. I don’t think there’s room at add any seals with the
crank bushings, but I’ll check it out if I tear it back apart.Prepare to be boarded!
April 7, 2015 at 3:41 am #13460IF YOU think it is crankcase leak or seals double up on the oil and try. if there is an improvement then you are on the right trail.
April 7, 2015 at 2:18 pm #13473Many Antique outboard manufacturers specified 40 weight non-detergent oil in there motors. This gave them better crankcase sealing – It’s worth a try …
April 7, 2015 at 5:43 pm #13494Well, I doubled the oil mix on the Neptune and fired it up in the
test barrel, and learned a few things!
#1- I’m an idiot (Yesterday when I thought the throttle valve was closed, it was wide open)
#2 – When running an outboard with a 5:1 fuel mixture, the wind always switched directions,
blowing Chinese like smog in your face!
#3 – The throttle keeps working itself open if your hand isn’t on the grip. (is there suppose
to be a spring on these twins to prevent that?
#4 – The exhaust noise is objectionable after 20 minutes, when there’s no exhaust tube attached.
All said it done, it ran for twenty minutes without dying. I wouldn’t can it "smooth", but
it did idle down fair. Without a prop on, I couldn’t really do any "high speed" tuning.
I may recheck the compression for kicks to see if it’s come up any from 60 psi, after
it’s total of 25 minutes running. I’ll put the exhaust tube and prop back on and try again
when it gets nicer out. Twenty mile an hour wind and in the thirties is not my idea
of fun. The Neptune did pump water nice, and cylinders ran cool to the touch, but
of course my test tank had 1/8" of ice on it this morning!Prepare to be boarded!
April 7, 2015 at 5:55 pm #13497great job.
April 7, 2015 at 6:29 pm #13498Awesome, looks like your on the right track…
classicomctools@gmail.com -
