Home › Forum › Ask A Member › Neptune Outboard afraid of water
Viewing 2 posts - 21 through 22 (of 22 total)
  • #13502
      Congrats and Good Luck!
      What part of the country are You from?
      Steve A W
      #13511
        Land of 10,000 Lakes, many ponds,
        and one stubborn Neptune.
        Checked the compression after the 20 minute run,
        and it was up from 60 on both cylinders, to
        68 and 70, but I’m guessing all that extra oil had
        something to do with that!
        Put the exhaust and prop back on and threw it
        back in the test barrel…….. it did start, but the
        longest I could keep it running was about one minute.
        It kept back firing thru the carb. Adjusting the high speed
        did not seem to help. When it died, I’d have to choke it
        to restart. Not sure if I have a carb or fuel flow problem
        now, or it’s all from the crank bushing sucking air.
        In the previous 20 minute run, it didn’t backfire once!
