Home › Forum › Ask A Member › Neptune twin cylinder help needed
  • #284030
    Dave Beach
      Recently acquired a complete 1940 6hp twin and a 1939 9hp twin needing fuel tank, carb inlet cover, and exhaust downpipe.
      1. Any manuals available?
      2. If not, any spec sheet available for various electrical or fuel settings?
      3. Supply of the missing parts for the 9hp?
      Beachblu
      #284045
        I had 2 of them.
        Point gap is .020 plug gap is .025.
        Found point gap was changing when I moved the mag.
        With the mag handle at 5:00 O’clock (Fast) aligned with
        tiller handle, I gaped each set at .015 aligning the point
        cam follower with the flywheel key. Moving the mag
        to the 8 O’clock (Stop) position I found one set of points
        was closing to .010 and one set was opening to .022.
        If I could get it started – the high speed was 1 ½ turns out.
        I could never find any combination to get it started.
        No matter the mixture screw setting or the amount of priming
        it wouldn’t start.
        If I got it running and shut it off and it wouldn’t restart.
        I was later told the starting issue may have been bad
        condensers.
        Motor over heats when running a full throttle for an
        extended period of time.
        The exhaust is also an issue. It is the same size as
        the 4 hp. motors. It’s way too small to move air through
        a 9.5 hp motor so performance suffers. The pipe itself
        has a poor mounting system so it’s constantly vibrating
        and destroying itself. I brazed a small brass tube in the
        pipe to make a sleeve where the bolt goes through.
        This stabilized the pipe somewhat but the sleeve adds
        to the exhaust restriction problem. While the gear case
        looks to be bullet proof the shape is a big drag through
        the water.
        I jacked with the motor every day for almost 4 weeks
        and never went out without a backup motor to get me
        back home. I would run into people that wanted me to
        stop so we could visit but I was always afraid to shut it
        off. I cleaned it up, everyone liked the look, but eventually
        sold it for a 1/3rd. of what i had in it. When I got a
        second in a buy one you buy them all deal I gave it away.
        Even though running the motor (or trying to) was a
        disappointment the experience was still worth the
        investment to me. Just letting you know what you
        may be getting into.
        Here is some video. https://youtu.be/EuJlTpriSCE
        #287803
        Dave Beach
          Well, cripes ..just found your thought provoking ideas Mr Boathouse. I’m finding I should have walked away from these 2 motors. After futile attempts to get ignition to respond….there just isn’t any. I spent time “boiling” out the carb and using gravel to clean out inside of the fuel tank. Can’t figure out how to dismantle the twist grip throttle. Have loosened up the transom clamp screws that were frozen
          All in all, I’ve lost enthusiasm for these two Neptune twins. The 9hp is truly a parts motor, but someone better than me would likely put more into the 6hp, which is a complete motor…
          Beachblu
          #287807
            I experience the same frustration with mine Dave. This is what makes up the tiller. It appears I cut off the grip. Cant remember if that is necessary to replace the cable. Memory is failing me. Guess I need to save notes as well as pictures. After learning this motor wasn’t something I would enjoy running, I used the “If it don’t go chrome it” approach. Took it to a few shows for display only. Found someone that likes the shinny stuff and passed it on at a considerable loss. Tubs.
