Home Forum Ask A Member New coils no spark 1956 15 hp evinrude
Viewing 10 posts - 11 through 20 (of 51 total)
  • #217475
    trainsnmore
      I took my digital caliper and set it to your dimension and checked across the coils. I had a reading of 4.464. This is from the original installation of the new coils. Do you think I can set the air gap this way bearing in mind to watch the circumference points of the coils not touching the flywheel.
      #217492
      Evinrude 25
        Yes, before I made the ring, I used to line up the coils with the boss and check with the caliper. It worked OK too but with the ring, it would be a quicker set up.
        #217546
        RICHARD A. WHITE
          trainsnmore, I sent you a private message
          classicomctools@gmail.com
          #217636
          trainsnmore
            How do I check continuity from end of spark plug wire to the coil?
            #217658
            pm-t2
              These systems are so simple. If the parts are good, you can almost always put a no spark condition down to either something grounded out that shouldn’t be or wires run to something they shouldn’t be.
              You haven’t answered my original question. Did you verify that the coils are connected to the proper set of points? You can set the coil positions and test the shit all you want. If the coils are hooked to the wrong set of points, it will not fire no matter how mad you get at it. Or me. Not that I care, lol.
              All of this crap about air gap and distances and using setting rings is overthinking personified. Jeez. I’ve been setting OMC points since I was a kid and never used any special ignition tools or devices. I use a screwdriver to remove and replace them. I use my effing thumb to position them on the mag plate. The coil heels can only get shoved in so far. The only thing I’ve ever worried abuot is if the heels hit the flywheel or not. If they hit, shift them inward. If they don’t hit, leave it alone. I’ll stack any motor I’ve tuned up against anybody elses. I’ll guarantee you that theirs won’t run any better than mine, whether they used special tools or not. It ain’t rocket science, eh.
              Best,
              PM T2
              #217659
              trainsnmore
                Here are a couple pictures. One of the old and the new. I believe they are right. Let me know if you disagree.
                #217660
                trainsnmore
                  E327C7E8-7D54-44F8-8B68-35BF97C96960
                  9D416CF0-6F93-4D29-9556-926ABA9A6CEC
                  • This reply was modified 4 years, 1 month ago by trainsnmore.
                  • This reply was modified 4 years, 1 month ago by Mumbles.
                  #217667
                  crosbyman
                    Canada Member - 2 Years
                    with coils primaries connected (one is grounded)
                    stick one probe of the VOM in the plug boot spring clip and one touching the engine body set the meter above 10K ohms range or better yet use a digital meter
                    you MUST see 4-8Kohms on each wire if not the coil secondaries are open or the plug wires are open
                    simple test … post results
                    #217669
                    crosbyman
                      see pic
                      #217672
                      Evinrude 25
                        Look good to me! you should get the spark.
