this post is 4 years old it it is recommend to open your own post (topic) and not resurect old ones….so as not to get things confused.
your secondaries HV pins should read 4-8 KOhms when measured with one of the primaries.   if you are on the proper scale of your meter.Â
your primaries should read close to 0-1 ohms between them selves.
reading OPEN from the boots  plug connections may show OPEN if corroded or open in a bent section of the plug wires
