Home › Forum › Ask A Member › New Member Introduction
- This topic has 28 replies, 13 voices, and was last updated 8 months, 1 week ago by The Boat House.
March 21, 2024 at 7:52 am #286085March 21, 2024 at 8:03 am #286086
Hi David. It was my pleasure meeting you and seeing the Magic Barn. I will try and plan a trip around one of your meets. I will bring the Fastwin so hopefully someone will be able to run it for me on a boat. It runs great in a barrel.
March 21, 2024 at 8:15 am #286087March 21, 2024 at 8:18 am #286089The body shop did an amazing paint job!
"Every time you remove a broken or seized bolt an angel gets his wings."March 21, 2024 at 8:24 am #286090hi Gary, welcome to AOMCI. I wish I had your skills and time ! to restore these oldies like you did.
Just to add to Seakaye12’S comment I would like to caution you also 🙂 The round B&S aka Mikuni round pump are great on lawn tractors with 4 stroke engines. Some have had problems with them reasons related to excessive fuel-oil mix ending up in the pulse line. I have used them myself but can’t say is had problems. I try to resll most of my refurbs .
that said the square Mikunis are apparently the ones to use if ever problems creep up on your beauty or simply mount a regular OMC square pump over a plate ( just line up 2 drilled holes behind the pump)
IF you don’t have a copy yet the Johnson ” bible” red book (or white) is a “must have” see this link.
https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
For 20$ you get a 400 page+ service manual covering just about anything on these oldies (late 40s to mid 60s) carbs, magneto, gear case timing etc…. Just download and have it printed locally and spring bound with plastic cover sheets . make for nice flat reading 🙂
see ex pages
March 21, 2024 at 8:29 am #286096Thanks. The paint shop did a nice job. They matched paint to original using parts that the paint color was an identical match to spray can Vintage outboard paint. They used a special camera and had a single stage Urethane Enamel mixed up for the chemical durability. They even gave me paint codes if anyone needs them. “Don’t know if I am allowed to post them.”
March 21, 2024 at 8:41 am #286097Thanks Crosbyman. I will definitely get the RedBook. Great idea of having it printed. For older people, having an actual book manual seems more accessible than computer access. I am sure younger people may differ. As a retired mechanic, you can never have enough tools. I do have the timing tool and the coil adjustment ring.
March 21, 2024 at 9:04 am #286098they predicted years ago that “paper” would be phased out with all the new fancy gimmicks and on-line access to info…never happened 🙂
my recent purchase was a 200$ cdn Brother 2710 4 in 1 BW laser printer. works great … no Iphones for me !
March 21, 2024 at 9:21 am #286099Welcome aboard Gary! That Fastwin is beautiful
March 21, 2024 at 10:19 am #286100Hi Gary, YES that fastwin is a beauty! I have one that is a twin to yours. Except mine has a white propeller! I wish I lived closer to that pine tree club chapter. I would sure like to see that Magic Barn in person. It should be on the map of Historical Places!
Welcome dale
