Home Forum Ask A Member New primer bulbs?
  • #1874
    wiscoboater
      Is something different with the new Atwood primer bulbs? I had an old one on my 77 Johnson 35 and it would not pump up. Went out today, bought a brand new line, bulb, hose assembly and put my Johnson end on it. Same thing… wont pump up pressure. Swapped a real old bulb and line on and it pumps up ok. Are the new EPA compliant bulbs different that I can’t get them to pump up?
      #19042
        How old is the old one? They used to have "real" check valves in them. They’ve improved them within the last 10 years or so till they barely work. They depend on gravity to seat the valves. Hold it so the flow direction points upward as you squeeze it. It should work better once it gets liquid in it.
        #19050
        johnyrude200
          Make sure your connector at either end of the line doesnt have an air leak. You know how sometimes the right connector somehow just doesnt seat correctly on the male end? Or is a ‘hard’ connection to plug in?
          I had a line that wasnt connected well to the motor, but somehow didnt make a good seal. Primed the bulb at least 30 pumps before I felt a little gas making its way umthrough the bulb. After another 20 pumps, it started dribbling out of the connector. Replaced the connector and if works A-OK.
          #19065
          wiscoboater
            Can the single line connectors be taken apart and the Orings replaced like the dual line connectors?
            #19066
            johnyrude200
              Ill let some others comment on that. I will say that whether they are or aren’t, they are so inexpensive compared to the 2-line system, that to me it isnt worth the time or hassle to replace a $0.15 o-ring. I just swap out the connector, plus the new stuff is plastic; old stuff is metal and lends itself to repair work. Plastic just plain breaks in general.
              #19073
              benchrascal
                Frank had it right ,the supplier of those Attwood bulbs went to great lengths to mention the bulb must be vertical when pumping up .They only last one or two seasons with the gas we have around here.
                #19075
                1946zephyr
                  One other thing that would help too. is push the little check valve down with a plastic nozzle of a WD-40 can while you squeeze the bulb. That tends to help the fuel flow through the line faster.
                  #19192
                  billy-t
                    I would agree, the Atwood ones i have used go hard as a rock in a year two at the most for me.
                    #19215
                    jw-in-dixie
                      I have been using a WM-Atwood, I guess, for many years. Each Spring on the first outing it is hard as a brick. Takes both of my old thumbs to press it at all. Strange, on the next use it is soft and flexible. All summer it works fine. I wonder why? I use Non-E gas only. I wonder if the oil softens it?
                      JW in Dixie
                      #19218
                      Michael
                        International Member - 1 Year (includes $3 online payment fee)
                        I find that the OMC/BRP primer bulbs to be the best
