Home Forum Ask A Member NGK B6S sparkplugs discontinued
  • #241836
    billy-t
      I have been using the B6S plugs as an alternative to the J6C but now NGK is discontinuing the plug. It recommends BR6S as a replacement, does the R factor have any negative implications for my old outboard?
      Thanks for sharing your knowledge and time.
      BT
      #241849
        The R is for resistor style. Your AM radio and sensitive electronics won’t get scrambled using them but you may have a bit weaker spark at the plug if used on a points style ignition system. Resistor plugs are meant more for Capacitor Discharge (CD) ignition systems.
        What’s this world coming to? No more B6S plugs? First it was the shorty bantam BM6A and BM7A plugs being dropped and replaced by resistor plugs and now the mother of all plugs, the B6S?
        #241853
        James Calamon
          The R is for resistor. They added a small resistor to help with radio noise from the ignition system. Should have no effect on sparkplug operation.
          • This reply was modified 3 years, 9 months ago by James Calamon.
          #241861
          crosbyman
            According to a fellow called Ohms… the hightest voltage drop in the secondary path to ground would be in the non-conducting air-gap of the plug.
            How much the noise suppressing resistor would affect the park’s ability to jump the gap would have to be measured with a scope.
            anybody got one….Mr.Mohat maybe πŸ™‚
            #241863
              The older points style magnetos in our motors need all the help they can get with strong magnets, clean and polished points, good condensers, solid core wires, soldered connections and good terminals to get a good spark at the plug. The last thing they need is a resistor in that chain.
              True, a points motor will run with R plugs but it might suffer crappy idling and develop a high speed miss or stumble.
              Can anyone confirm the B6S has been discontinued as I couldn’t find anything after searching for it?
              #241890
                Right on the NGK website….
                https://www.ngk.com/ngk-3510-b6s-nickel-spark-plug
                #241893
                  Well, that blows. My OMC classics all run better with the B6S than they did on Champions.
                  β€œEvery 20 minute job is only a broken bolt away from a 3-day project.”
                  #241895
                  crosbyman
                    time to scavenge the plug shops.
                    #241904
                    jcrigan
                      I bought eight of those 3510’s a month ago. West marine was selling them for $1.99. They were clearing them out. Tried first to buy them at O’Reileys then at Autozone. Person couldn’t find them in their inventory.
                      #241905
                        News flash: They are cancelling them because nobody in their right mind needs them anymore. Just us. I always liked my Champions anyway, but J6Cs are probably next. I better order a shop pack now…..
