Home › Forum › Ask A Member › Non-channeling Waterproof Grease
  • #1775
    lightfoot
      My 1939 2 hp Neptune 2A39 is supposed to use a "non-channeling waterproof grease". What do you guys recommend.
      Secondly, is the hole at the rear of the gear-case above the prop the fill hole, or do you pump it in through the typical drain hole toward the bottom?
      Thanks.
      #18269
        Two popular choices for gearcases are Lubriplate 105 (now sold mostly for engine assembly),
        and "corn head grease", see viewtopic.php?f=2&t=919
        I was taught to fill from the bottom, to prevent air pockets from forming.
        #18271
          Sent you a PM
          #18289
          JOHN D.
            I fill from the bottom, and I vent it by removing the top screw on the prop shaft bearing holder (what do you call this part?).
            #18291
            lightfoot
              Thanks for all the suggestions guys, I had no idea what to use. Very helpful forum!
              #18294
              Ron Devries
                +1 for John Deere Corn Head Grease, works well for me.
                #18366
                lightfoot
                  One more question, I’m going to fill the gear housing from the bottom drain hole as suggested, but should I fill it until the grease starts to come out of the top hole?
                  #18384
                    YEP!
