I believe all RDs at least thru RD18 are the same. For RD18 size is 11/16 inch OD x 1/2 inch ID. That would have 3/32 inch thickness. I have bought from an assortment that VIP Auto had behind the counter.
Interesting, .500 x .100 would be .700 OD x -500 ID. The numbers I have are .687 OD x 0.500 ID. So the factory outer diameter would be only .013 inch larger. I got my numbers from a supplier cross reference table. That does seem a reasonable equivalent.
This reply was modified 6 years, 11 months ago by olcah.
