Home Forum Ask A Member ohms reading 1940 mercury K4
  • #166587
    benji41
      Need the ohms readings for the coils of a Eisemann Model# 72H part# H24-896 magneto
      Jim Benjamin
      #166615
        If yours is the same type coil as the Maytag Eisemann coils, maybe this
        information is good…..
        Re: Maytag 72 coil replacement
        The twin coil secondary has grounded centertap.
        Thats why one side can fire with the other grounded.
        Also, measure resistance across the detached spark plug leads and you will see 8k ohms. about 4k for each side of the coil.
        I would think less than 1k or less ohms on the primary, but hopefully someone
        will know for sure on your coil.
