Home Forum Ask A Member Oil to use in old air cooled outboards?
  • #181323
    eltoquad
      What oil are you using in your old 2 cycle outboard engines and why?
      #181325
      wbeaton
        BRP or Amsoil is my preference because they burn clean and leave less mess after running. Cheap oil leaves lots of black residue all over my white Mercury midsection that is hard to clean. Also, better oils smoke less. This is a visual concern for me since I use a busy public boat launch and run many antique motors at 8:1.
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #181326
        amuller
          I would probably use a synthetic oil intended for air-cooled two stroke engines such as chain saws, etc., on the assumption that air-cooled power heads run hotter. “JASO” etc. The TC-W 3 oil is formulated for water cooled outboards.
          But this subject brings out all sorts of opinions. And “review” sites have proliferated on the Internet, most apparently produced by writers who know nothing about their subject.
          #181327
          Phil Budne
            Note the subject line says AIR COOLED!!
            http://www.omc-boats.org
            #181328
            wbeaton
              Yup. Sorry. I missed that in the body of the text. I only have one air cooled motor that I run. Use any good quality TC-A oil. If it has a picture of a weed eater or a chainsaw on it you are good to go.
              Wayne
              uccaomci.com
              #181330
                I use Huskvarna chain saw oil
