Home Forum Ask A Member Oily flywheel
  • #169968
    mrhtx21
      I have a 1958 evinrude 5.5 (model 5516)
      And have quite a bit of oil under my flywheel and around magneto
      Usually this would point to top crank seal leak but I dont show it having such a seal from parts diagram
      Any ideas what ir might be causing the leak and/or how to approach it
      #169971
        Correct, there is no seal. Only a slinger that throws the oil off the rotating shaft. From there, it is sucked back down to the intake manifold through drillings in the crankcase. They only made a few millions of them that way, so can’t all be bad.
        I suggest you check for excessive bearing looseness. If that is ok, clean it up and run it. Blow through the crankcase drillings, if it will make you feel better.
        #169979
        crosbyman
          Canada Member - 2 Years
          see pic from red book
          slinger
          • This reply was modified 5 years, 11 months ago by Mumbles.
          #169996
          labrador-guy
            Crosbyman is right on! I have one of those 5 1/2s apart right now. The slinger knocks the oil down that leaks by the bearing. There is a drilling that takes the excess oil and drains it back into the carburetor side of the reed valve. Check that drilling for blockage. Some times to much sealent on the reed plate, blocks the oil return hole. OMC has a oiling system that brings extra oil to the main bearings. That system uses crankcase pressure to circulate gas/oil mix through the engine. You probably seen the hose going from the bottom main bearing to the top bearing. Extra oil/gas goes back through the engine.
            dale
            #169997
            mrhtx21
              Would the pressurized fuel tank conversion have anything to with causing it
              #169999
                I can’t imagine how it would..
                #170001
                labrador-guy
                  Trying to send some pictures. Make sure this hole is not blocked. This system of drillings should catch a bunch of oil if it is working correctly.
                  dale
                  IMG_0507-1024x768
                  IMG_0508-1024x768
                  IMG_0506-1024x768
                  #170007
                  Robert Wight
                    Dale,
                    Was looking at your photo #1 and made me recall when I was replacing the manifold and reed plate gaskets on my ’54 CD-11. Judging by location of the upper/lower bearing oil feed hose, your motor is a 1958. Looks like the oil feed drilling to the reed plate is in a different location between the ’54 and ’58?
                    01A-Manifold-Removed
                    #170013
                    outbdnut2
                      Was it stored upside down?
                      #170015
                      Robert Wight
                        Don’t know about my motor. It was sitting on a dolly when I found it.
                        • This reply was modified 5 years, 11 months ago by Robert Wight.
