Home › Forum › Ask A Member › OMC 584477 coils made in Hong Kong?
- This topic has 21 replies, 13 voices, and was last updated 6 years ago by
wbeaton.
December 1, 2019 at 8:14 am #188347
certainly possible for anything to fail but it would appear that in general these coils are fine. It would seem that BRP arrived at that same conclusion if they decided to outsource these things to HK .
jmhoJoining AOMCI has priviledges 🙂
December 1, 2019 at 8:56 am #188348I think the cheap coils on eBay are seconds. Meaning they didn’t pass QAQC the first time. I’ve bought a few dozen of them now and find the build quality between coils to be inconsistent. They still work fine. I haven’t had any failures yet.
Wayne
December 1, 2019 at 11:48 pm #188403I haven’t bought any of these coils recently but have been considering it for use on non-OMC motors. I’ve noticed in pictures (and maybe read it somewhere) that some coils use epoxy or something to glue the winding to the laminates. This is in lieu of the metal tab that is bent over to hold the winding on. Is it possible to get these windings off or should I make sure to get coils with the metal retainer tab?
Thanks
KirkDecember 2, 2019 at 8:17 am #188407The Chinese coils are indeed epoxied to the laminates. You have to be careful pressing them off. I have used them for a number of coil swaps now and haven’t irreparably damaged any.
Wayne
December 2, 2019 at 10:17 am #188415
This reply was modified 5 years ago by
Tubs.
December 2, 2019 at 11:56 am #188419I bought the black Chinese coils. Tubs’ link didn’t work for me. I’d be interested in coils that weren’t epoxied.
Wayne
December 2, 2019 at 12:12 pm #188426I bought the black Chinese coils. Tubs’ link didn’t work for me. I’d be interested in coils that weren’t epoxied.
The link Tubs posted worked for me; the ebay item number is
361504731938
You can search that way if the link does not function for you. The e-bay seller is Doug Russel.
December 2, 2019 at 1:03 pm #188427Thanks Tubs. They only have the one picture so wasn’t sure.
KirkDecember 2, 2019 at 2:55 pm #188442Thanks, seakaye12. I’ve seen those coils before. They are too expensive for me once you add exchange and shipping. The last round of black coils I bought were $10 USD each with free shipping.
Wayne
March 4, 2020 at 4:29 pm #196649The OEM coils manufactured in HK are superior in quality to the cheap black coils purchased direct from HK on Ebay branded Zhongfadz. I have had good luck with the current production BRP / OEM coils. I have used quite a few of the Zhongfadz coils also. I have not yet experienced a failure with them, but I will say that it takes more flywheel RPM to make them spark. It is not easy to notice this on motors 10HP and under in most cases. I know they made my rope start RD-16 a real bear to start. I swapped them out for a set of German coils in that motor and it made a world of difference. I don’t mind the cheapies in small motors at all, but I like to use the OEM coils especially in my 18s and up. I have been running a 56 Evinrude Fastwin 15 with Zhongfadz coils in it for 2 summers now without issue. I do think it would be easier to start with OEM, but it isn’t difficult so I keep running them to see if they keep working.
-BenOldJohnnyRude on YouTube
