Home › Forum › Ask A Member › OMC cork fuel tank float replacement
- This topic has 14 replies, 11 voices, and was last updated 8 years, 11 months ago by
twostroke.
November 1, 2017 at 10:08 pm #8585
I’m restoring a couple ’50’s OMC pressure-style fuel tanks, and the cork floats are really, really nasty. I’ve had the brilliant (??) idea of soldering on a brass float outta’ a Holley 4-bbl …just because I have several in my stash. If anyone’s got a better, less crude idea for a replacement, I’d love to hear it.
Thanks!
Jim
November 1, 2017 at 10:24 pm #66883I, too, am wondering if there’s a better, more-modern solution. The available replacement from marineengine.com is also a varnished cork, and I would have thought by now a more modern alternative would be available.
cork from marineengine: http://www.marineengine.com/newparts/pa … OMC0302559
I tried using a cork from a wine bottle, but it sank like a stone in the gas. I guess it’s not big enough to offer enough displacement to float the mechanism.
November 1, 2017 at 10:44 pm #66884A number of years ago, I bought a couple of Nitrophyl floats intended for antique Ford fuel gauges, intending to modify them for carb floats, but never did.. I’ll have to do some digging to find the details, or even find them if I still have them.
November 1, 2017 at 10:52 pm #66885This probably isn’t where I got them, but you get the idea
https://www.macsautoparts.com/ford_mode … t&x=18&y=8November 2, 2017 at 12:33 am #66889I wonder if a plastic wine bottle stopper might work. Tan color, but not a natural product. I shaved one down today to plug a missing gas can cap. I might have to go to the store soon to continue the research. I know they are at least alcohol resistant. Pretty close dimensionally, too.
November 2, 2017 at 12:48 am #66891Anonymous
Coat a new float with model airplane dope. Fuel proof when coated and still look and operate the same.
November 2, 2017 at 12:57 am #66892Actually, a new cork float should have an alcohol proof coating already. Old ones had a shellac coating, which alcohol dissolves.
November 2, 2017 at 2:27 pm #66911Yup! If you coat the wine cork just like you’d coat a cork carb float it will not soak up the gasoline. Beware that not all brands of hot fuel proof model airplane dope work. I had one brand that flaked off.
DaveNovember 2, 2017 at 3:16 pm #66915I’d be trying your idea if the
carburetor floats are big enough.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
November 2, 2017 at 4:56 pm #66920My local ACE Hardware sells very large cork stoppers. They are about the same size as the old tank corks although they are tapered. I coat them with airplane dope. They work fine.
