OMC Low Tension Ignition Coil
Home › Forum › Ask A Member › OMC Low Tension Ignition Coil
- This topic has 4 replies, 3 voices, and was last updated 4 years, 11 months ago by fisherman6.
April 29, 2019 at 4:23 pm #174535
What keeps the spark plug wire in the ignition coil in the BRP 0502881 ignition coil assembly? There does not seem to be any type of keeper that keeps the wire from coming out of the coil in the assembly. The existing coil on the other cylinder appears to have something tyere to hold the wire in. Am I missing something?
-BenOldJohnnyRude on YouTube
April 30, 2019 at 10:13 am #174550Don’t the wires screw into these type of coils? On old NFG coils, I can grab the wire near the coil with a pair of pliers and unscrew it. Some of them seem to have a sealer or adhesive on them which was applied in the factory.
April 30, 2019 at 12:32 pm #174555On this particular coil, which is a new BRP part purchased new last year from Marinengine, it does now screw on. It simply pushes on a smooth spike and I cannot figure out what is supposed to hold it in place. If I need to epoxy or otherwise apply some type of adhesive, I can do that. I just wanted to see if there was something I was missing or didn’t know about.
April 30, 2019 at 10:12 pm #174591I don’t think you are missing anything Ben. I don’t know of any of those coils where you could actually remove the spark plug wire… I would just epoxy it in place and hope for the best….
May 1, 2019 at 9:39 am #174609Thanks Don. I’ll do that and hopefully that will eliminate any further issues with it in the foreseeable future.
