Home › Forum › Ask A Member › OMC points/tune up kits obselete??
- This topic has 14 replies, 9 voices, and was last updated 5 years, 11 months ago by fisherman6.
May 12, 2018 at 4:25 pm #9901
Was looking for OEM OMC points on marineengine, it says "not available". Same notation for the 171522 tune up kit….
This can’t really be possible, hopefully….
Anyone have more info?May 12, 2018 at 4:34 pm #75846Hopefully Marine Engine is just out. I have not heard about BRP not making the kits anymore? Maybe so though.
Eventually it will happen. If our members don’t support and buy OEM parts, they will eventually stop making them. Its likely going to happen one day down the road. We are all to blame for this, myself included.
May 12, 2018 at 5:34 pm #75849I dug into this a few weeks ago & was told they were just out of stock by Seaway in WA. I think it’s time to go to my contact at BRP to see if something else is happening?
These points have been made in Turkey (I believe) forever. Their quality has always been far superior to anything else in the industry. Most of the time the cost (as a tuneup kit) is about the same if not cheaper as the junk on the market! I sure hope BRP hasn’t made another brilliant executive decision. I will check & get back to you.Dan in TN
May 12, 2018 at 11:58 pm #75860Try 172522. or777679.
May 13, 2018 at 10:53 am #75891https://www.ebay.com/itm/BRP-Johnson-Ev … SwqaJaVkM9
Crowley Marine has the 777679 kit for just points and condensers.
May 13, 2018 at 12:15 pm #75895OK, well maybe BRP changed the number on the tune up kits, but marineengine does not reference the number, will look on the BRP site…
May 14, 2018 at 1:14 am #75941That is the OMC System Matched parts (same parts) that BRP sells to distributors. It’s what I can buy. Crowley just happens to still have some in stock. That is good, but at a premium price. ME was selling those kits for around $23? Of course they cost less than that. The kit is by far the best way to buy the points, condensers, & oiler wick. I should have an answer for us some time tomorrow. I have sent an email message to BRP to clear up wheather this is a temporary B/O or a BAD decision. #580148/#777677 are on not listed either.
Fleetwin if you just click on the BRP number on ME site you will see the OEM number listed along with Sierra & every other vendor. That OEM number is OMC System Matched part.
Dan in TN
May 14, 2018 at 1:31 am #75942You can get almost any BRP OEM part thru Dusky Marine in Florida for 25% off MSRP. They currently show the points/condenser kit under part #172522 or 777679 for $22.49 after discount, or points set only under part #580148 or 777677 for $8.99 after discount.
On the home page, scroll down under Boats, Motors & Parts and select Evinrude parts, then enter you desired part number. I’ve ordered lots of new parts from them with no difficulty and usually very quick shipping.
Hope this helps.
"Every time you remove a broken or seized bolt an angel gets his wings."May 14, 2018 at 1:40 am #75943Sorry, I guess since we are talking vintage OMC motors, I should have said OEM OMC parts! I ordered the 172522 kit from Dusky about a month ago and got it with no problem, so guessing that ME is currently just out of stock.
"Every time you remove a broken or seized bolt an angel gets his wings."May 14, 2018 at 3:34 am #75955The system matched parts are OEM. Just a different P/N. Most likely they BRuP should just use the OMC OEM P/N to keep things simple. But BRuP is not that smart.
