Home Forum Ask A Member OMC single hose tank question
  • #64486
      If the o-ring around the pin leaks, you can usually hear or see it while pumping the bulb. Usually.
      #64505
      outbdnut2
        quote Adam1961:
        It seems that the valves on my tank are working as they should, as I get pressure or vacuum in the tank when moved to a warm or cold space with the cap shut.
        With the cap shut and the fuel line plugged into the tank, you should not get a vacuum – the one-way vent should prevent that, but if you are talking about getting a vacuum when the gas line is not connected to the tank – yes, that’s right.
