Home Forum Ask A Member OMC Universal Coils and Magnetism
  • #254890
      Crosbyman, That’s as good a possibility as any at this point, and makes sense. Thanks!
      Mumbles, I “believe” I checked the ohm readings first without the plug wire,
      and later with, and were virtually the same reading. At any rate, both coils got’s new
      plug wire off the middle of the same 50 foot roll.
      It does make me feel better that yours tested at .9 on the primary.
      Most likely well within specs, and yet higher than my presumed good coil at .3 on the
      primary.
      Hopefully I can spin the flywheel next week and check the actual spark. Thanks.
        Buck:  What I meant was to join the test leads of your ohm meter together and see if you get a reading. An auto ranging meter should show 0.0 ohms while a regular digital meter will give you the resistance of the leads themselves, 0.7 ohms for example.
        #254966
          Mumbles, I have never checked my leads resistance on my “auto ranging” nor
          any meter for that mater, but you bring up something to keep in mind.
          The first coil I checked read .3 on the primary, the other 2.0, and both
          were checked multiple times with the same results.
          I may be putting the flywheel back on the motor tomorrow and check for
          spark……. that will be a good start if I have spark on both cylinders!
          aquasonic
            My meters are non-auto ranging, so they have an adjustment knob to zero out prior to measurements. I just touch the leads together, then turn the knob until the reading is zero ohms. This takes the resistance of the leads out of the calculation.
            Improvise-Adapt-Overcome
