Home Forum Ask A Member Opposed Twin Water Circulation
  • #258392
      Regarding the 1937 Johnson model 210, opposed twin, 3.3 hp, or
      any similar designed engine, whether is has a water pump or is
      prop thrust / siphon fed to the cylinders as mine is, (can’t think of the proper term),
      doesn’t the incoming water always go into the bottom of the cylinders,
      and exit out the top, so the water jackets are sure to stay full of water?
      I’m putting the motor back together, cleaning up the water lines, etc., and found
      one line with an old solder repair where it “Y’s” off to the cylinders, was loose.
      After taking the line apart and cleaning it, I went to put it on the motor temporarily
      to mark it for soldering, and the only way the lines don’t “cross”, or even hook up,
      is if the water supply line goes into the top of the cylinders.
      Can this be correct for this motor?
      The water feed from the “scoop” aft of the prop comes up the starboard side of the motor.
      I confirmed that when the gear case was off, and again today by blowing air into the holes
      where the water lines go into the gear case.
      I also looked at “before” photos,( before I took the motor apart), and the lines are not crossed,
      and the supply would have to be on the starboard side.
      Signed, perplexed. Thanks for your thoughts.
      DSCN3348
      DSCN3351
      Trying to feed into the bottom of the cylinders, the top line won’t hook up.
      DSCN3383
      joecb
        Every motor I have encountered the water goes in the bottom and out the top. Could your lines be bent wrong or switched right to left.
        #258398
          Joe, I’ll have to look again tomorrow, and hope the new day (and Easter)
          brings clarity. I just found this Johnson 200 (same motor, but earlier?)
          and indeed, the water is going into the bottom side of the cylinders.
          I thought I tried arranging the lines every way possible, but maybe not!
          Johnson-200-file-photo
          dave-bernard
            could the bottom line run behind the top line ??????????
            #258405
              Dave, as I said, I “thought” I tried every which way, but will try again tomorrow.
              After looking at the photo of the Johnson 200, I’m convinced that a previous owner
              hooked the lines up incorrectly, feeding into the top of the cylinder instead of the bottom.
              Perhaps he bent the lines out of whack. In the 200 photo, the bottom line (into the cylinders)
              is aft of the upper line.
              I wonder if the one line was cut off during the repair and now to short to be hooked
              up properly?
              Happy Easter!
                I think with these push/pull, pressure/vacuum systems, the water would have to enter the cylinders at the bottom to purge all of the air out for it to work properly.
                #258407
                  Maybe I’m looking at this too simply but – in the “before” picture, the line connecting to the top of the cylinders follows the starboard side of the driveshaft tube all the way up to the powerhead.   In your “top line won’t hook up” picture, that line is now routing up along the port side of the driveshaft tube.  Maybe you just have the two lines crossed (top line routed incorrectly – should be to the right of the cylinder bottom line)?   But if the starboard side line is the incoming water supply line, then water would be going into the top of the cylinders which doesn’t seem right.
                  • This reply was modified 2 years, 10 months ago by Bob Wight.
                  #258416
                    This is my 1933 Johnson OA-65. Cooling water enters
                    the bottom of the cyl. and exits at the top on this motor.
                    Having the water exit at the top of the cyl. increases
                    the siphoning effect .
                    • This reply was modified 2 years, 10 months ago by Tubs.
                    #258420
                      The garage is heating up, so will have another look-see soon.
                      Starboard orifice at gear case is the supply from the scoop for sure.
                      Looks like we all agree that the water should go into the bottom
                      of the cylinders, out the top. Mine has to have been plumbed wrong….
                      hopefully not from the factory.
                      Will let you know if I resolve this! Thanks.
                        The water lines on the Johnson 210 are now hooked up correctly,
                        with the supply going into the bottom of the cylinders.
                        I wonder how long the P.O. ran the motor with the lines plumbed
                        incorrectly, and how well it cooled the motor?
                        I didn’t notice any internal damage from over-heating, so
                        hopefully no harm was done.
                        I had to re-clock one of the water line’s elbow fittings a cylinder
                        to regain correct alignment, along with tweaking the lines into
                        submission so the clamp would fit.
                        I re-soldered the bad joint at one “Y” with the lines all screwed in place,
                        not to chance a bad fit by soldering the line on the bench.
                        The water lines, where they insert into the gear foot, have no grommet,
                        no room for said grommet, etc., so I may try to work some kind of sealant
                        around them, as the lines are not that tight of a fit in the gear foot.
                        DSCN3390
                        • This reply was modified 2 years, 10 months ago by Buccaneer.
