Home › Forum › Ask A Member › Other old motors – should I?
- This topic has 15 replies, 9 voices, and was last updated 11 years, 5 months ago by
shoestringmariner.
April 5, 2015 at 7:32 pm #1114
So I have an opportunity to add 3 more non-running motors to my non-running pair.
There’s a 3.3 Evinrude and 10 HP Johnson QD-10, both look complete near me and also a late 50’s Johnson 10 hp (supposedly runs) a little bit further away…prices from $80 to $150. Also some period correct pressure tanks….Am I nuts?? They look so darn cool!!
If the larger motors are needle bearings, can run them on a lighter fuel mix with todays oils?
April 5, 2015 at 7:42 pm #13380It sounds to me as if you are on the fence. If your situation is like most of us, and you have the money, buy the motors and start planning a much larger storage area. This addiction is well know for taking a normal person and making them a hoarder, a collector of sorts. The only medication is buying more….I personally have no flipping desire to be "cured" 😈
classicomctools@gmail.comApril 5, 2015 at 7:48 pm #13381For me, it would depend almost entirely upon cosmetic condition. If they look good, and are complete I might go for them (although I’d try to talk them down since they don’t run)
April 5, 2015 at 8:47 pm #13384Thanks guys. Yes, appears to be all complete. I’m concerned because I don’t know how scarce parts are for these particular motors as I’m finding that parts for my TN-28 are obsolete, and if I’m not mistaken, Johnson made over a million of these motors. I *think* I’d stop at these as it would give me a few motors to use the HP range that I figure my boat can take (12′ cedar strip…thinking 10hp max?)
April 5, 2015 at 8:59 pm #13385I’m with Richard on this one (can’t get enough). I usually tell myself, "when in doubt don’t" but with old motors it seems to be "when in doubt do". I at least try to keep it narrowed down to a certain range of motors (make, model and year).
April 5, 2015 at 9:01 pm #13386I would have to pass on these just based on price. Unless they are in super nice condition cosmetic wise and have spark. I think you could find a better deal at a swap meet. As far as the TN TD models go for 20 to 40 bucks around here any ways you could have about a dozen of them. Of course if there is enough room on the back of your boat you could run 2 TN motors.
April 5, 2015 at 9:29 pm #13387The 3.3 Evinrude is pretty well made, the two I have just needed a points cleaning to run. The 1950’s Johnsons are the "universal mag" twins with many available parts from many sources. BRP, marineengine.com, iboats, etc. etc. Value is up to you. Searching Craigs tells you what motors sell for in your area, prices vary by location. If the 10’s ran, with tanks, they would sell for around 250 to 300 near me.
April 5, 2015 at 11:32 pm #13390Thanks again guys
Kerry, you’re not far from me. I’m in Southern Ont, and anything vintage here seems to command a bit more. (asking values anyway)Here’s the 3.3. It is such a freaking cool looking motor. Says it only has spark on one cyl. I assume it means a bad coil or dirty points.
April 5, 2015 at 11:37 pm #13391darn, image failed to work
April 5, 2015 at 11:42 pm #13392You have to upload it to an image hosting website first. postimage.org is a good one
