Home Forum Ask A Member Painted Powerheads?
  • #163859
      What year did OMC start painting their powerheads black instead of the same color as the motor ?
      #163926
      dan-in-tn
        It was when they moved assembly to the southern plants. The assembly system for motors changed. The powerhead was built, painted, & dressed before being bolted to the midsection. Other models were painted before the casting were machined (lost foam blocks). It all depended on the casting & assembly plant.
        I believe the year was 1984 for 1985 models.
        Dan in TN
        [/b]
        #163937
          Thanks Dan! ’84 is as new as I have at the moment and they are painted all one color.
          #163951
          Tinman
            Speaking of paint on powerheads, was there a time when they didn’t paint anything under the cowl? I have an early 50’s qd and everything is bare underneath.
            #163965
            Tinman
              IMG_4195
              #163969
              wedgie
                I have read that they didn’t paint powerheads that were replaced under warranty.
                #163971
                dan-in-tn
                  {content}I have often wondered about that? QD & RDs from the early 50s are not painted. I’m not sure when they became painted, but have some of both without paint. Funny thing is I have several JW-10s and all are painted. Since JWs didn’t come out till 1952 maybe that’s our answer?
                  Dan in TN
                  • This reply was modified 6 years, 3 months ago by dan-in-tn.
                  #164220
                  fisherman6
                    I don’t know about all the different series. The QDs started getting painted powerheads on 1953 from way I can tell. I have 2 1952 QD-13s with bare powerheads, and three 1953 QD-14s with painted powerheads. For what it’s worth bith if my 1954 RD-16s have painted powerheads as well.
                    -Ben
                    OldJohnnyRude on YouTube
                    #164319
                    fleetwin
                      that’s a beauty!
                      #164324
                      Tinman
                        Thank you! It’s a qd-12 and I also have a qd-14 that is in great shape. I think they have seen very little use. Proud to have them and hope to get them up and running someday.
