Home › Forum › Ask A Member › Part number for a thermostat kit for a Lark III?
Is there a kit for the thermostat replacement? Do you just replace the thermostat and gasket? ’61 Evinrude Lark III, 40HP, 35525
Where do you guys find the kit numbers anyways? I can never find actual kits, just individual parts.
Here’s a link to OMC kits on Marine Engine:
http://www.marineengine.com/parts/brp/
1937 Champion D2C Deluxe Lite Twin 1954 Johnson CD-11 1957 Evinrude Fastwin 18 1958 Johnson QD-19 1958 Johnson FD-12 1959 Johnson QD-20
“Every 20 minute job is only a broken bolt away from a 3-day project.” "Every time you remove a broken or seized bolt an angel gets his wings."
Just the thermostat and cover gasket. Unless some genius removed and tossed the black housing and check valve.
Don’t forget the rubber thermostat seal also, yours is probably worn/damaged…
fleetwin wrote: Don’t forget the rubber thermostat seal also, yours is probably worn/damaged…
Nope,, none on subject motor
frankr wrote: fleetwin wrote: Don’t forget the rubber thermostat seal also, yours is probably worn/damaged… Nope,, none on subject motor
You are so right Frank, no rubber gasket around the thermostat. The gasket is under the plastic check valve cup….D
305196 gasket 18-1055 378065 thermostat 5005440 18-3553 305266 housing 305198 gasket 18-1056 305197 valve 305199 spring
