found an Archimedes outboard model with a bore of 54 mm
that needs a piston with a diameter of 53,95 mm
with a calculator help……that’s 2.124 and you need 2.121 !
wrist pin is also not quite correct, but it depend how desperate you are
and how handy
the million dollar question is…..
do I have an extra pair and what is the value ? 😮
shipping from the Netherlands ??
see if I can find them and what the other measurements are in inch.
btw . I have a lot Penta outboard pistons with diameter 53,95 mm but all have two ports in the skirt
that makes it for your model useless
