Home Forum Ask A Member Piston Rings for 1962 JW-17
  • #165474
    campcozyme
      Hello All,
      I have a 1962 JW-17 3hp Johnson Seahorse outboard that my husband is trying to get running better. He has taken it apart and how broken one of the piston rings. We have tried to find a replacement and we are having a really hard time and we don’t want to junk the motor. Would anyone know where we should look or if its even possible to find a replacement. A place out of Vermont that we buy are parts does not have any and doesn’t think they are available.
      Any help would be wonderful as we are heartbroken!
      Thank you.
      #165475
        they seem available but expensive… 0378412 – Rings , Standard reconfirm the# before purchasing if you do……approx 75$
        try classified adds on aomci site or maybe a member can give you a set
        https://aomci.org/classifieds/
        • This reply was modified 7 years, 2 months ago by JACQUES.
        #165477
          stanley
            Try Dan Gano at gano@ganotech.com Call him at the number on the website,he usually answers or calls back soon.Your best option is probably finding some used ones.
            #165485
              Rings are $5.00 each plus 10% shipping.
              Click on the online piston ring catalog.
              http://www.ringspacers.com/
              #165488
                If you use the $5 rings, be ready to file notches on the ends to clear the alignment pin on the piston as they will come with square ends. The size needed for standard rings is 1 9/16 X 3/32.
                #165499
                  • This reply was modified 7 years, 2 months ago by Tubs.
                  • This reply was modified 5 years, 1 month ago by Tubs.
                  #165515
                    If you want stepped ends on the rings
                    Dave can supply them at an extra cost.
                    In the past I have just removed the pins.
                    Removed the pins???? Wow, Tubs, that took guts to say that. I’ve never done it though, so have no first-hand experience with the consequences–or not.
                    #165601
                      I’m sure I’ve seen some ported cylinder engines without pinned rings,
                      and wondered about it. Also on any engine when one assembles the
                      rings staggered, I often wonder how long they stay in that position.
