Home Forum Ask A Member Piston Rings – Johnson JW – 16
  • #225577
    mikekolbus
      Folks
      trying to locate 2 sets of piston rings for a 1960 Johnson 3 HP , JW – 16 part # 486277. any assistance would be appreciated
      Mike K
      #225582
        Hi Mike. The old P/N 486277 has been superceded to the current P/N 378412.
        M.E. is mighty proud of the one set they do have in stock so you might try Googling the 378412 P/N to see what happens.
        http://www.marineengine.com/newparts/part_search.php?part_num=378412
        #225593
        wedgie
          I wonder if Dan Gano or Ed Elliot might have some for a reasonable price. I could use a couple of sets too..
          #225597
          mikekolbus
            Mumbles,
            Using the updated part # found one set on ebay for $ 14 but so far that is it. I hate to pay M E their overpriced part
            I will keep looking
            Thank you for the help
            Mike K
            #225598
            aquasonic
              Courtesy of Tubs. I’m wondering if you could mail them a ring, and they may be able to match it up. http://www.ringspacers.com/
              #226675
              mikekolbus
                Thank you very much
                Dave is making me 4 sets of rings. Great resource for discontinued rings for the vintage engines
                Again I appreciate your assistance.
                Thanks
                Mike
                #226678
                  If the new rings are square cut on the ends, you will have to file a small notch on each end to clear the locating pin on the piston. It’s not hard to do but you do have to make sure you don’t file too much material away or break the ring doing it.
                  #226681
                  mikekolbus
                    Dave filed the rings for me. This resource is very knowledgeable and will work with you. The cost was $ 36.00 for two sets of rings including shipping. I felt that was very reasonable.
                    Mike
