Home › Forum › Ask A Member › PIvot post for points and spring clips
- This topic has 18 replies, 8 voices, and was last updated 5 years, 4 months ago by crosbyman.
November 28, 2018 at 1:23 pm #157439
My previous post didn’t format correctly. It was supposed to be all blue, all same size but it didn’t come out that way, although I tried to edit it 3 times Using BBCodes. I’m going to try again and see what happens.
316 Stainless Steel Hairpin Cotter Pin for 7/64″ to 9/64″ Clevis Pin Diameter, 0.031″ Wire Diameter, packs of 25 – 3.10 per pack #92375A002
- This reply was modified 5 years, 4 months ago by Steve D.
November 28, 2018 at 2:09 pm #157454In a pinch, I’ve ran motors in the barrel without a retaining clip installed and relying solely on the bonding clip to hold the points in place.
If I tried doing it while out on the lake, I’d probably break down miles from the ramp!
- This reply was modified 5 years, 4 months ago by Mumbles.
November 28, 2018 at 4:08 pm #157473316 Stainless Steel Hairpin looks another good solution β¦ no McMaster around here
and those hairpins are pretty pricy on Amazon…I,ll try EBay and discounttown if not avaible the orange box store may have them if all else fails I’l use the fishing lure clips or twist some Stainless steel wire around the pivot post
where there is a will there is a way β¦ right ! π
November 28, 2018 at 5:57 pm #157485crosbyman, I can send you a few of those and a few of the real ones if you want. If I just put them in a regular letter envelope I think they’d go through ok to Canada.
November 28, 2018 at 8:12 pm #157492Looks like those hairpins would be easier to install than the stock clips without flying all over the place!
- This reply was modified 5 years, 4 months ago by lindy46.
November 28, 2018 at 9:23 pm #157494Tiny things go well it envelopes if you put them on clear Scotch banding tape and then fold it over to make a none sticky sandwich.
- This reply was modified 5 years, 4 months ago by garry-in-michigan.
November 28, 2018 at 11:27 pm #157502sound’s pretty nice of you to offer β¦ thanks
Jacques Desjardins
721 Allrd street
Montreal Q.C.
Canada
H4H 2C4Joining AOMCI has priviledges π
November 29, 2018 at 6:12 am #157504Had the same thing in mind Garry, thanks. crosbyman if you tried to send me a PM I don’t think I got it. If you needed to send me an email it’s sdpiazza (at) aol
November 29, 2018 at 7:45 am #157505Steve,
sent you an email with same infoI had clicked on the ..Set this as private reply box on the previous reply with my coordinates assuming that would send a private reply
I guess that does not workβ¦β¦β¦β¦? or is not the intent of the clicked box
