Today I was changing the grease in my PO-15 gear case, and found the drive shaft tube full of un-burned fuel/oil mix.
I would think that this should “drain” off somewhere during normal use, so am curious as to where it should go.
By the way, do not remove that drain screw when the motor is in the house 😎
David Bartlett
