OK, the way I read this is that the "high point of the point cam" is only 10 degrees, a very narrow band, when compared to the conventional universal mag motors. At least you know exactly where on the cam to set the points on these low tension models. Needless to say, using the timing fixture avoids any guess work. Perhaps I am missing the point of the bulletin.
I always rotate the crank a few revolutions after setting point gap (if not using the timing tool), while watching the points open/close, to ensure the gap is correct.
