Home Forum Ask A Member points pads
  • #285322
    DougConrad
      I’m attempting to rebuild my 1956 Evinrude 3 hp. I have a Sierra Tune-up Kit (18-5006). Everything looks pretty straight forward except I can’t figure out where the pads go.
      Any other tips would be appreciated.
      Thanks, Doug
      #285325
        The wiper felt goes in a clip that sits atop a post, underneath
        the coil laminates.
        DSCN4362
        crosbyman
          it is all in the book !!  everything you need on oldies mid 40s and up to 60s
          carbs  magneto  GC  PH  timing etc…   400 + pages   just downloadand print locally
          https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
          #285339
          DougConrad
            Thanks for the replies. There are no clips on this motor. How necessary are the felt wipers? I suppose I could make some.
            I will order the manual.
            Thanks,
            Doug
            #285341
            labrador-guy
              Thanks,
              Doug
              Doug, if this motor was mine I would put some grease on the rubbing block of the points and forget about any wipers.  Millions of automobiles on the highways use a little grease on the points rubbing block and it works fine.  As the block wears the grease keeps it lubed.  JMHO
              dale
              #285354
              crosbyman
                well… the oiler pad oils tha cam  which reduces wear on the points rub block.
                the clip is worth crazy money last time I looked …  try to find a used one  they are all the same.   Somebody must have one in a parts bin… 🙂
                the felt can be cut from a sticky felt pads.. install with felt on cam  and  moisten with 2 drops of  oil I use gearcase oil
                #285357
                  As Dale suggest you want to put some grease
                  on the back side of the rubbing block of the points.
                  Automotive points would come with a little capsule
                  of grease to be placed in this location. As the points
                  ware grease is applied to the point cam, prolonging
                  the life of the points.
                  #285370
                  crosbyman
                    I always assumed the grease was for the pivot point itself… the  oiler pad  takes care of the the rub block but I guess with no oil pad… grease would help… for a while
                    #285386
                    T….in Wisconsin
                      Are you sure there’s no clip?
                      Have you already removed the coils, clip is tucked under a coil heal and not easily seen if the wiper is missing.
                      Here’s a pic of the clip and wiper removed, this may help.
                      #285493
                      T….in Wisconsin
                        Replaced all  Mag components on the 67 Ducktwin
                        Pic of felt wiper pad installed.
                        Wiper bracket is included with the new points kit.
