Home Forum Ask A Member points pads
  • #285495
      US Member - 2 Years
      Yes even Mercury 6 cylinder direct reversing  motors have the same part & they include a points spring tentioner to adjust spring pull on the points to save the rubbing block on the points & lube the felt pad. I got my huge felt pads from rebuilding surgery tables, long story! Even sent some to Frank.R
      #285651
      John Gragg
        If you are still in need, send me a pm as a reminder and I will look in my ignition parts box. Pretty sure I have one, maybe 2, brackets and wipers.  I will let you know.
        John Gragg
        RIverside, CA
        Just starting in the hobby, please be patient.
        48 Sea King 5hp GG9014A
        49 Sea King 5hp GG9014A
        48 Johnson TD20
        49 Johnson TD20
        54 Johnson QD15
        55 Johnson CD12
        57 Johnson RJE-19M
        57 Johnson RDE-19
        #286402
        DougConrad
          Thanks for all the helpful replies. I was sweeping up my shop the other day and guess what I found? Clip and pad now install as per instructions.
