Home › Forum › Ask A Member › POR-15 49208 U.S. Standard Tank Sealer
- This topic has 4 replies, 3 voices, and was last updated 2 years, 12 months ago by
crosbyman.
April 28, 2022 at 1:06 pm #259119
is this stuff good and can it be used to seal other things like.. .a cork float ?
April 28, 2022 at 8:34 pm #259142Just last week I used POR 15 fuel tank sealant 49216 to seal a tank on a 1938 Handitwin. The 49216 has a silver metalic tint to it. This was the first time I used POR 15 to seal a tank. When the sealant dried it left some areas that look as though the sealant is transparent. When I rubbed my finger over the area it does feel that the area is coated. This makes me think that the metalic tint did not stay mixed with the sealant liquid. I did dip a cork float to see how it would react. Dipping the float left a heavy coat on the cork , and I wondered if it might make the float to heavy. If I do another I will brush the sealant on the float with a small brush. Maybe do a couple of thin coats. POR is hard to clean up. I used a cork to seal the tank fill while sealing . I put the cork that I used in a bottle of acetone when I was done with it. Acetone didn’t seem to dissolve the POR 15 or so I thought. I checked the cork after seeing your post and the cork is clean. Acetone made the sealant release from the cork. I was surprised. I have used POR 15 black paint in the past and nothing seemed to dissolve it.
Rob
April 29, 2022 at 12:47 am #259149thanks for info
April 29, 2022 at 11:16 am #259162
Before I stopped putting a sealer on corks I
tried Kreem fuel tank sealer. I bushed on 3
coats (as I remember). It seemed to be working
fine until after about 3 years I went to use the
motor and the float bowl was running over.
Found that the sealer had separated from the
cork and the cork was stuck in the float bowl.
I cant say for sure but I suspect gas got under
the sealer at the hole for the float pin (needle).
The increase in weight didn’t seem to be a
problem. If your going to try it I’d suggest you
check it each time before you plan to use the
motor. This was a motor I used quite a bit so
it took a while. I have used both Kreem & Red
Koat sealers. Both state to use acetone to
remove them.
Tubs.A "Boathouse Repair" is one that done without having tools or the skills to do it properly.
April 29, 2022 at 12:03 pm #259165i’ll use new floats 🙂
