Pre-war Mercury/Wizard gear cases
Home Forum Ask A Member Pre-war Mercury/Wizard gear cases
Viewing 10 posts - 1 through 10 (of 28 total)
  • opposedtwin
    US Member - 2 Years
    Topics: 261
    #197929
    I have taken 2 of these gear cases apart in the last few weeks and have noticed some similarities and some differences in them from model to model. One is a 1940 (mercury) sea king and the other is a 1940 K3.
    This is the water pump/gear case of my 1940 sea king (Mercury K1). Couldn’t get the water pump cover off so I lost my patience and drilled holes, installed screws, added dish soap and it came out pretty easily after that.
    Couldn’t get the water pump cam pin out on this one, so I figure it really doesn’t matter. As long as the pin is in there allowing the prop shaft to turn the cam, then the rubber oscillator will rotate and pump water.
    Removing this pin was must have been problematic because in later water pump housings they added a small recess to allow the pin to be driven out easier. (See pics below)
    Can you think of any reason why it would be essential that I get that pin out?
    Thanks!
    Scott
    opposedtwin
    US Member - 2 Years
    Topics: 261
    #197935
    Any reason I shouldn’t use this oscillator style impeller? It has a small chunk out of it but still rotates. Problem may be that the small chunks are plugging the cooling lines somewhere. After I get it running I’ll see if it pumps water ok.
    Bob, I remember you said someone made reproduction oscillator style impellers. Can you refresh my memory who that was? Was it Joe Poole?
    Topics: 51
    #197945
    Club member Brian Wilcox makes some, but I don’t know if that includes Merc/Wizard
    fifty20ne
    Topics: 75
    #197946
    Yes,
    here is the link.
    http://fergusonpoolemarine.com/enginecoolingsystem.html
    It’s my thought that the rubber must still have some give? softness
    for this style of pump to work correctly! All of mine are as hard
    As hockey pucks.
    opposedtwin
    US Member - 2 Years
    Topics: 261
    #197947
    Yes,
    here is the link.
    As hockey pucks.
    Hmm…I guess I hadn’t thought of that Bob. I wouldn’t think the softness of the rubber would matter as much as with the rotax type impellers with vanes which need to bend and stay flexible.
    When I get it all back together, I’ll see how these pump water. Even the kd4 I took apart last week has an oscillator type impeller. The water pump housing is a 7 slit type but would not accommodate a vane type impeller. Maybe it’s a pretty early kd4. I will look at the serial number and see what it says.
    EDIT: the kd4 is #123829 so it’s a kd4-1 and part of the first big batch of kd4s they made in 1946. Probably used up kb housings before they moved onto the 3 slit type and rotax impellers.
    green-thumbs
    US Member - 2 Years
    Topics: 43
    #197973
    The early pattern (16 square hole) water pump keep teaching me lessons. I believed they only came with iron or steel eccentric cam.
    I will be dining on crow, ran into a brass eccentric cam that is NOT a
    from a later pattern (7 slit) water pump.
    Salt and pepper, but, no butter I am trying to lose weight. Not much nutrition in crow and its taste leaves a lot to be desired. Excellent
    remedy for a swelled head.
    Louis
    Cam on left is from a 7 slit water pump
    Cam on right is brass, but, clearly for early pattern (16 square hole) pump.
    edit
    Today I got curious and ambitious. The four 16 square hole water pumps were removed, taken apart and are now getting tune up.
    Just for the record two had iron/steel eccentric cams, one had a brass
    version and the remaing pump will be assembled using an eccentric
    cam from a 7 slit water pump.
    Louis
    green-thumbs
    US Member - 2 Years
    Topics: 43
    #198141
    All is well that ends well…sort of…as with many old Merc projects, things go well until you run out of parts or patience.
    EGG prop nuts, spring to retain eccentric can drive pin and warm temps
    to go outside to paint.
    I often tear into multiple items at once. The advantage is some are likely
    to be complete and serve as a reference to complete the remainder.
    The empty water pump casting took a little doing as the original type
    eccentric cam was not available. Mr. Grubb came to rescue with the later eccentric cam and assurance that it could be used instead. The
    bacl up plan to fire up the lathe was not needed.
    The later eccentric cam can be adapted to work with the rubber clutch
    or sheer pin.
    Sharp eyes will note a 3 slit vane type water pump assembly and a
    later pattern propeller on a 16 square hole water pump. I have a
    damaged early pattern propeller that needs some careful metal
    work to be made usable. I am too cheap to throw away anything that
    can be salvaged with more time and effort than most would consider
    sensible.
    Louis
    labrador-guy
    US Member - 2 Years
    Topics: 72
    #198145
    Louis nice look’en parts there! Does this mean we will hear one of those Wizards growl this summer?
    dale
    green-thumbs
    US Member - 2 Years
    Topics: 43
    #198155
    Possibly, depending on how long “virus house arrest ” lasts.
    Being cooped up with a lot of almost ready projects may work
    wonders .The water pumps were removed from several work in
    progress motors and will be reinstalled tonight.
    Louis
    fifty20ne
    Topics: 75
    #198166
    Pump Info
    Notice the spring in second video?
    That is why I feel the rubber must have some compliance
    to it, in order to act like the spring?
    https://www.apexequipmentltd.com/hollow-disc-pumps/
    https://www.youtube.com/watch?v=Qtc7tHRTAHA
    https://www.youtube.com/watch?v=vKgrPnttOi8
    • This reply was modified 4 years ago by fifty20ne.
