Home Forum Ask A Member Preserving old decals
  • #1245
    stanley
      What should I put on old decals to preserve them.I use my motors,but don’t want to lose the original decals.
      #14206
      thepetrolist
        One simple procedure is to spray them with some kind of good quality automotive grade clear coat. That preserves the decal as-is and protects it really good.
        #14208
        shoestringmariner
          Be careful what you use for clear as some will yellow. (lacquer does I think. maybe someone can clarify that)
          #14215
            • This reply was modified 6 years, 4 months ago by Tubs.
            • This reply was modified 4 years ago by Tubs.
            #14234
            mr-asa
              As usual, Tubs has many good points.
              There are things out there that can clean old decals appropriately, I am not sure how the old decals were constructed, so I’m not sure what those things are, but if you get me that info I can check it out. I would recommend (if you have one) using a decal that is pretty much gone from a restoration/preservation standpoint as a test bed to find out what will damage the decals before you start trying to preserve them.
              #14287
                US Member - 2 Years
                Compatability & bonding are the keys here. I have bought original decals that fail from age, wish you luck & let us know your results.
