Home › Forum › Ask A Member › Pressure Tank Questions – QD15
  • #289089
    John Gragg
      Finally getting to the QD15. I have a tank with a new (nos) diaphram and gaskets. My questions are:
      Seems like the plunger (aluminum rod plunger w/ 9 hole diaphram) doesn’t have as much up/down travel as I imagined. Normal?
      When I pump the plunger I get fuel in the glass bowl, but I can see the fuel ‘leak down’ ever so slightly afterward. Normal?
      1st experience with a remote tank. Thanks for any help/advice.
      Best Regards
      John
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #289098
        The check valves in the tank are not perfect nor expected to be, so I wouldn’t worry about the leakdown.
        Since the pump is pumping gas to the carburetor and hopefully no gas leaks anywhere you probably are ok.
        #289101
        John Gragg
          Thanks Frank,
          Yes, I hadn’t tried running it yet but did so today. Couldn’t get it to stay running, had to keep priming the carb to get fuel into the bowl. Finally took a close look at the tank and found I had not screwed the pump housing down tight enough (a couple of minor air pressure leaks). Fixed that and now it runs like a top! First run since I got it almost a year ago. My CD12 did just as well! Two runners, time for cosmetic work.
          Thanks again,
          Best Regards,
          John
          John Gragg
          RIverside, CA
          57 Johnson RJE-19M
          57 Johnson RDE-19
          #289105
            great news… “patience brings joy”  …said the fortune cookie 🙂
