Home Forum Ask A Member Pressure to Pump
  • #203625
    Matthew Pieklik
      Hi all , I am ready to convert my 15012 Super Fastwin from a pressure tank to a fuel pump. I am using a Quicksilver pump kit 89977a 1. Is there any benefit using the pressure port as opposed to putting a fitting on the bypass cover. I know if I use the pressure port, I’ll have to remove the flapper. Or is the bypass cover just that much easier? If I drill through the bypass cover what size hole should it be. The cover is already cast with a hole I can thread for a brass elbow. let me know your thoughts. Thanks , Matt.
      #203626
      mercuryman
        I would only use the bypass port if there is around hole cast in the port cover. Then you can tap with 1/8 pipe thread and drill hole bottom. There is more to it than just removing the flappers you also need to block a hole. There is a good video on You Tube.
        #203628
          Absolutely, use the bypass cover!!
          #203634
          Matthew Pieklik
            Bypass cover it is! Thanks.
            #203702
            crosbyman
              plug the pressure nipple with a short stub of hose and a fat screw or bolt
