and if you plan on using a dual line hose set up with a pump eqpted engine may as well try to modify the purge valve and route polluting fuel oil juices back into the tank which will need to used with the cap loose .
this will prevent the dumping of “purged” fuel & oil in the water 🙂
see recent posts on the mod required to do this
