Home › Forum › Ask A Member › Problems gapping points on QD-19
- This topic has 27 replies, 14 voices, and was last updated 5 years, 5 months ago by
frankr.
May 4, 2020 at 10:13 pm #202027
Just replaced the points, condenser on my QD-19. I used the OMC kit with points (580148). Here’s my problem: (1) Using my timing tool, placing the pointer between the marking points, using a multi meter with audio, and turning the adjusting screw, the points move back and forth but do not open always having continuity. (2) Not using the timing tool, at the widest point of the cam, my points will not open to .020.
I have played for 3 days, replaced screws, fiddles with the points, I figger three things: (1) the new points are bad, (2) filing down the points themselves, but shouldn’t have to do that on new points or (3) the rubbing block is too small. I’ve used two different set of points.
Any ideas I sure would appreciate it!May 4, 2020 at 11:13 pm #202030So I just tried this myself tonight on an RD-21 and have to say it never seems to be as convincing as I’d like it to be. The books commonly gloss over this – but it does seem like there is a bit more of finesse required than they let on. What sort of seemed to work for me was to make sure the eccentric screw was most of the way down and then have the retaining screw tight enough to hold the base but still able to move the base if you push on it. I pushed the base towards the condenser to give enough space to make a gap and let the eccentric screw do it’s job to shrink or widen that gap. I still wasn’t entirely convinced I got it and still think there is some magic I’m missing. If I don’t have it right when I test fire tomorrow I’m going back to the feeler gauge and maybe figure out the correct position with the timing tool vs trying to figure out when exactly the lobe on the timing cam is at its highest.
May 5, 2020 at 12:03 am #202031Btw with the meter /tone method you don’t need .020…. the moment you lose tone is perfect. That is exactly when the points open and cause the collapse of the magnetic field and ignition spark
http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
May 5, 2020 at 12:26 am #202034BTW if you still have the old points which presumably were simply used…. compare your new points to the old set
I for one, seem to recall a set of points which had a shorter rub arm. Sounds crazy but tue ….. in any event just compare old and new points…..
keep us posted on progress
May 5, 2020 at 2:55 am #202037I’ve heard complaints that the new points today aren’t what they used to be, quality-wise.
May 5, 2020 at 6:53 am #202042I’ve had this same problem with a set of new points.
May 5, 2020 at 8:57 am #202050Thanks for the video. Believe me, I’ve watched this 20 times and many others. This is what makes me think my points are faulty cause I’ve followed these and others to the “T”. I’ve ordered some Sierra points to see if maybe there’s a difference. Unfortunately, I deep sixed the old ones and cannot reuse. I’ll re-post when I get the Sierra’s. Thanks everybody for the comments.
May 5, 2020 at 10:10 am #202056please perform autopsy when you get the new points…. we all need to know… hopefully the new points will work 🙂
May 5, 2020 at 10:30 am #202057Throw put the new junk point set, put the old ones back in. This happens way too often. Old points unless very worn down or pitted will be better than the new ones.
Edit, I see you threw out the good ones. Oops.
This reply was modified 5 years, 6 months ago by
squierka39.
May 5, 2020 at 11:27 am #202066If you remove the small adjusting cam screw, you should be able to set the new points correctly with a bit of prying.
